XL1200S Riders... 2-1 exhaust options?
Hey fellow Sportster "sport" riders... (if ya'll are out there)...
i'm running a supertrapp 2-to-1 megaphone exhaust which dumps a significant boost of horsepower to my flywheel. Also have screaming eagle upgrade with heads, pistons, cams & rings... My problem is, i'd like to either mess with the number discs in the exhaust to make it a bit more "harley" sounding down low OR does anyone know of any other exhaust that keep the same level of hp but sound more throaty?
Your chasing something you already have. Depending on your personal preference removing or adding defuser disks raises either torque or horsepower. Reads like u have about the finest assembly of se components that you can massage your mill with. If you've dynotuned 4 correct AF & balance T&HP with the disks your there brother. The sound of your machine is subjective. If you know someone you trust go out somewhere & have them ride by you on your bike. I'll bet it sounds pretty bad ***. Also try riding with custom hearing protection that alone may put the bass in your note. I traded my 01XL1200S in 4 my SG the guy that bought it is Air Force and shipped it to England, still registered last time I checked sure would love 2 have that machine back someday again. Have fun & ridesafe
Racing Jake... an open end cap? if i was to do that, wouldn't i still have to remove some discs to 'keep' the same level of T&HP? I guess if i'm too worried of loosing any power on the bike i should just leave well enough alone huh?
i'm gonna screw around with the exhaust this weekend and search out an open end cap. In the meantime, if i was to take off the closed end cap today and drive around to see if i notice a significant difference.... say there is a noticable difference, can i just put the closed end cap back and all will return to it was before? I know these exhaust work off the backpressure but i'm curious to go without and see although i want the option of returning it to normal as easy as possible. thanks!
Adrian Thompson
02-16-2013 04:12 PM
