08 Nightster wouldnt start
well tried to go to work this morning and when i hit the start button...nothing. think there is something wrong with ignition switch. I noticed a couple times in last few rides that the first time i would hit it wouldnt do anything, but second time did. Considering i know nothing electrical probably have to take it in? Unless this is common and there is an easy fix. I know my battery is good, checked the charge just to make sure. Also i noticed a little sticking with my key when taking it in and out, but dont think its related. All lights come on ect, you hear the fuel pump, just no spark. Any advice would be great. Thanks
Just resolved my Nightster starting issue. Symptoms were exactly the same, solution. change the battery of your remote detector (whatever that black thing is, normally hanging with keys). Mine is 2008 so it seems the battery lasts for 2 years.
Issue solved, and Nightster is willing to ride with me
if you put the bike upright while having the key fob and the sig lights flash then change the fob battery...also check the other set (key fob) if you got one, i got 2 when i bought my bike, but both batteries died by the same time...
...to prevent corrosion in electrical connectors use some dielectric grease
