New to the sportster bike.
Ok, I goffed up here a bit in translation, my falt.
I only slid the battery out far enough to get to the postive post, did not unhook any wires on the battery.
However it is entirely possable there might be a bare wire behind the battery and it got moved when I slid the battery back into place .
The shop guy said that they would start and run the bike every now and again for the next couple of days to see if the "no start" happens again so they can than test the system.
I was told that if they find nothing, there would not be any charge.
I will belive that when I get the call to pick up the bike in a couple of days.
When these type of things happen, You should always checks fuses first, then loose connections.
As long as there's no charge at the dealer, then you're good IMHO.
Glad to hear you like the bike! If you change the mufflers and intake, you could pick up some power if needed.
~Joe
~Joe
Definitely let the dealer assess - especially when it's a no-charge agreement if the problem doesn't persist. Hopefully it will act-up again so they can diagnose elec. Could be anything mentioned above - sometimes electrical issues can be a bugger to trace.
Welcome to the forum - you're in good hands. Nice scoot! By younger bro had same year/model & ended up installing 1200 UG which really made it a beast. Fun bike to drive, but unfortunately he had to sell. Good luck!
Well after 2 days sitting at the dealer they could not find anything wrong.
Bike would start for them every time they tried. There was no charge when I picked up the bike Friday afternoon.
However I think all they did was to try and start it every once in a while, I dont belive they even hooked it up to trace down the problem.
When I got it home I noticed some black electrical tape on the wire harness leading to the starter switch.
Never noticed this befor.
Apond inspection, I find splices leading me to assume that at some point in this bikes life the switch control box on the handle bar has been replaced.
I fired up the bike and tugged at all the spliced wires and to my luck the bike did not quit.
So I am thingking that the problem that accured out on the highway was a short in the start switch and kill switch as the wire from the start button runs through the kill switch.
I still need to take apart the switch box and look for bare wires or pinced wires.
willp76
06-08-2009 11:27 AM
