Got a Zumo 550 for the red mistress (pics of mount)
have the 550 also. i take it off the bike - have the wire all hooked up and i just hang it over the handle bar when the device is off (much of the time). would be nice to have a way to get the wire not hanging around. it is a nice device and thanks to those who posted up software choices. will have to check those out!
my hanging wire hook up is here:
http://www.s2ki.com/forums/index.php...age&img=729804
(load it and click on it to expand the size)
Since you have a "C" model, that's any easy fix. Run the power wire inside the handlebar riser and install a 2 pin SAE (battery tender) plug on the end. When not in use it stays hidden behind the speedo. Of course you'll need a mating connector on the end of the GPS pigtail.
If you do not care for Mapsource, you might want to take a look as the HD web site called Ride Planner. The link is shown below.
http://www.harley-davidson.com/wcm/C...p?locale=en_US
I like this site better than Mapsource. It seems easier to use to me. It allows you to set up a profile and then create and save routes. You can then download any of them directly to your Zumo.
