07 1200 low engine seems to stutter
Maybe I'm expecting too much from fuel injection on my 1200 low. When I'm at steady throttle,more at lower rpm,it seems to stutter,not a miss. Almost like a carbureted engine,that needed carbs balanced. I read that any adjustments must be made with a computer. When under load it runs fine. It has stock air cleaner, vance hine baloney cut pipes. Is there any way to improve the way it runs?,or balance cylinders? Tom
Here's a link to a great article that explains it far better than I can: http://www.harley-performance.com/harley-exhaust.html
Muffler baffles
I'm interested in hearing what you think when you have installed the baffles,and tested it.
I also noted that since I have mufflers with little backpressure,that the dealer would have to remap for that change. I hate to spend the bucks for the computerized option.
thanx,Tom
thanx,Tom
Just had an update from UPS. The "quiet" baffles won't be here until Tuesday. I'll post results as soon as I put them on.
I ran it for a couple of weeks with the stock exhaust. It did seem to do the same,but it was less noticable,due to quiet mufflers. I had thought about installing the V/H baffles,but only for a little less noise.
I had thought I may be experiencing what is called a lean misfire. I know they build these engines to run lean. I heard that you have to adjust the mapping to adjust for backpressure change. Has anyone had their engines remapped by the dealer? Tom
