Tank Lift question
hey bikerguy... you don't have to remove the tank... you can look into the following tutorial for some ideas:
https://www.hdforums.com/forum/sport...n-my-take.html
lift..
You need to raise front of the tank. Use cloth wrapped chunck of 2 X to prop it up.
Tucking all the wire connecters under tank is a tight fit but can be done.
Ignition can stay were it is but the bare bracket looks like crap - I used my coil bracket to remount it.
Good luck, take your time, have a few beers(always helps the patience).
plug wires
I'm pretty sure you can cut and redo the existing wires for your coil relocation. OR goto US Kool lines and order a pair of 10.5" wires in whatever color you want. Check out this pic to see what mine look like:
http://picasaweb.google.com/10383042...84821445250594
I originally went with 10" wires, but I think 10.5 would be a slightly better fit.
Have fun
Have fun
bikeyguy... cutting the stock wires and reassembling the connectors is such a painful experience you'll be taking antidepressants by the time you are done... one option is to buy a cheap ready-to-assemble kit for a 4 cylinder car at a auto parts store... another option is to buy a kit from uskoolines.com .. the simplest option is to order two Harley Davidson P/N 32014-09 which is the rear spark plug cable from an '09 Softail at $7.50 each
Billy Blaze.. thanks for the encouraging words!
