bolt-in cams for an 883?
Old 08-29-2010 | 08:01 PM
markmil's Avatar
markmil
5th Gear
Default bolt-in cams for an 883?
I've got a '00 883 with the SE air cleaner and Supertrapp 2 into 2 flat track exhaust. Will be buying adjustable forks from the old Sportster S model with dual discs, (still available and reasonably priced!), and shocks. I want to keep the motor as an 883 and was wondering if there would be any noticeable increase in power if I go with the SE bolt-in cams. I'm not looking to make the most powerful motorcycle I can, just a more powerful 883 with stock reliability. Anyone have any experience with that upgrade? Also, I read that stock cam sets must be ordered for certain tolerance variations with the engine cases, (otherwise they can make some gear whine). Are the SE bolt-in cams available for the different engine case tolerance variations?
Old 08-29-2010 | 08:40 PM
Mike07FLHTC's Avatar
Mike07FLHTC
You won't get much with bolt in cams on a stock 883. Your best bet is to make it a 1200. Or maybe some head work and the bolt in cams for the 883.
Old 08-29-2010 | 09:35 PM
woodworking1's Avatar
woodworking1
the 1200 conversion kits are very reliable these days. It is really the only way you are going to get more power from an 883. The cams are only going to make a noticable difference if you do the motor work to support them.
Old 08-29-2010 | 11:39 PM
wishbone550's Avatar
wishbone550
If you have your heads worked over the cams would help but otherwise they are just gonna make your bike sound better at idle.
Old 08-30-2010 | 06:17 AM
xFreebirdx's Avatar
xFreebirdx
That 883 can be souped up to be quite a hotrod. But as a rule cams are almost useless with out head work, IE: Stage 1, 2 or 3 heads.
Old 08-31-2010 | 04:38 PM
markmil's Avatar
markmil
5th Gear
Sounds like it won't be worth investing in cams. Oddly, I examined another thread about a "cams only" upgrade for the big engines and all replies were positive. Thanks for all the input.
Old 08-31-2010 | 05:57 PM
xFreebirdx's Avatar
xFreebirdx
The Big Twins (BT's) are a completely different animal.
Eddy883
02-26-2018 05:51 AM
Oneeye1964
05-04-2014 06:16 PM
Stonetone
02-05-2013 01:43 PM
cavalier2000
11-07-2011 09:51 AM
gus_flydude
Exhaust System Topics
03-21-2009 10:38 AM
Quick Reply: bolt-in cams for an 883?
