Vance & Hines Ceramic Scuffed!
I just installed some Vance & Hines Short Shots with the Black Ceramic on my Iron 883 and yesterday while I was riding, something caused a nasty scuff. I have no idea where it came from but needless to say, Im not happy.
Anyone know of any way to repair this? I know I can have it powdercoated again but was more interested if there was some type of "touch up" available?
I would post a pic but I am posting this from my laptop via wifi 33,000 feet in the sky...
I did the same.
Quoted from correspondence...
"You can try spraying some high temp flat black paint on to a flat clean surface, and using a thin paint brush apply gently on to the affected area of the heat shield. As mentioned before, the tone will not match, and who knows how long that paint will hold on with the heat. We do sell replacement heat shields if you are interested in replacing."
"The lower heat shield with the tip retails for $100.55"
This is directly from V&H's.
try this stuff
http://www.designengineering.com/cat...licone-coating
painted my chrome shields with it at comes out really close to the ceramic satin look on the black V&H shortys. i found normal high temp black paint comes out almost grey. if you use a little it might blend in, and hey its worth a try at only $10
heres what it looks like
Professor333
Exhaust System Topics
03-10-2019 03:41 PM
M_Sportster48
08-20-2015 09:18 PM
IamDiabolical
08-30-2012 02:36 PM
jordanball33
01-28-2009 09:34 PM
