Another FuelPak Thread
I took out my FuelPak this morning.
I noticed my bike was running like absolute crap when using it. It would rev on its own when warming up, stall a couple times like it wasn't getting enough fuel. It would pop as I rode, both accelerating and decelerating. If I let off the throttle it would feel as if it just caught a **** ton of a resistance.
I used the proper map for my set up (V&H 3" Slip Ons, 1200 Big Bore Kit, Stock A/C). Even confirmed with V&H rep.
Took it out and went for a ride. Feels like my old bike again. Only thing I miss is the throttle response the FP gives (if that makes any sense).
What the hell am I doing wrong?
I just installed a fuelpak on my 07 XL1200C and did not have any major issues like this. The first thing I would check is to make sure you calibrated the fuelpak correctly as per the following steps--
5. As the next procedure, after you have entered in your values for the first 18 modes, press the
mode select button to move to mode 19. Fully twist open the throttle and return to idle
position to calibrate the Fuelpak to your bike.
6. By pressing the mode select button twice, move to mode 21 and verify that it reads “0” with the throttle
closed, “50” at approximately half-throttle and “99” when fully opened; if not, repeat step 5. Do not proceed
to step 7 until mode 21 is verified.
I would check these again and see if that might be your problem. If you did all this multiple times then I would venture to say you might have a faulty unit.
which map were you using. If there were negative numbers, was the negative sign lit? Did you tripple check the settings along with the calibration? I know I transposed my map and it ran like crap. I thought this is bad. I rechecked the map and all was right, I was just using the wrong map.
fuelpak surge/stall problem solved
This step is Not for sportsters.. That thing is a hit or miss item. Some people love it some don"t. I am one who doesn't . I removed mine after having same issues as you and when I got on it to pull away from a truck coming at me it stumbled.... Well it stumbled its way to the trash can......
Not liking my fp right now.
Got vh blackout 2:1. Been on over 2 yrs running the map from the vh website (which i wrote into my book as well). A month ago, I changed my ac. The bike ran for ****.
Went on the site and found they had a new map this pipe that was completely different then the original. Wrote that one in the book ... double checked what I had originally in the fp matched what I had written down just in case then changed to the new map. This was way worse.
Called vh about 20 times. they gave me some settings to change on each call. Nothing worked.
Went back to original ac with original map. Bike does not run as good as it did before I messed with it.
