Stumped
No lights = bad battery/bad ground. Check the voltage on the battery. If you have 12volts (+/- .5), then check to make sure the terminals are clear of any corrosion. If there is no corrosion, then trace the battery ground all the way to the frame, looking for any frayed, kinked or burnt spots. If it is good, then do the same with the hot wire. I'm pretty confident you will find it there.
Ok. Got the volt meter. Not sure about the fuse on it, but I know where the ignition relay is. The ignition relay is a DYNA 2000 Digital ignition relay. As far as I know, that checked out fine when I last had it in the shop 3 weeks ago. Is there ANYTHING else I should be checking out before it pisses me off enuff for me to take it into the H-D shop?
Still Stumped
The battery, the fuses, the wiring, the ignition relay, the starter, are all checked out and everything is charged. But still no start up. Am I missing something? Or should I just freakin' take it to the HD shop? Ie's an ironhead, and alot of these young mechanics have NO knowledge of those models and how to fix them. HELP!!!!
Ok so here's how it works the battery positve goes to the main breaker first so if you show power with a test lite or meter showing 12 volts coming out of the main breaker then the next place it goes is to your ignition switch , is there power that far? and another wire off main goes to regulator power there ?, the battery also off the positive side goes to the starter on the lug so power there? Do you have a wire diagram to follow? You have to see how far the 12 volts is going.
