turn signal out- what to check?
my left turn signal is lit because the lights are on, and it blinks when i hit the left turn signal button. the right one is not lit, but does blink when i hit the right turn signal button.
i tried replacing the right signal bulb, and the new one also is not lit.
now i am trying to remember whether they should be dimly lit when the headlights are on (the left one is and the right one isnt)...
can someone tell me whether the turn signal bulbs should be on when the headlights are on?
and then, if so, thoughts as to where my wiring problem might be? or if not, then it would be the left one being on that is the problem- and what to check for that?
Could be a fuse, but unlikely if the turn signal works. Might be worth a check. Did you change the bulb? Some of the bulbs have 2 filaments, one may blow, but the other keeps working, worth a check (just hold the bulb up to the light, you'll see it. ) Might be a connector, under the seat, trace the wire back from underr your fender to a plastic connector, check that's tight. Try unplugging the connector and replugging it, look at where the wires enter the connector (both ends), are they all pressed in firmly?
