Clutch Cable Lube
Old 09-03-2006 | 07:35 PM
SportyPig's Avatar
SportyPig
Default Clutch Cable Lube
Need to lube my clutch cable..Got the procedure down pretty well (I think) any suggestions which oil to use??
Old 09-03-2006 | 08:16 PM
olesalt's Avatar
olesalt
Default RE: Clutch Cable Lube
'04 Manual says use Super Oil ( HD-94968-85TV ) on hand levers & cables. I haven't done mine yet so can't give you a cost.
Olesalt
Old 09-03-2006 | 08:34 PM
SportyPig's Avatar
SportyPig
Yeah, I read that in the Shop Manual...just figured there was probably something cheaper..and possibly better than a HD lubricant.
Old 09-03-2006 | 10:25 PM
liltrk's Avatar
liltrk
I use the H-D stuff. Works well, but I can't say its cheap.
Old 09-03-2006 | 10:31 PM
Shovelhead Bob's Avatar
Shovelhead Bob
WD40 and a cable luber.....
As long as you are doing your services religously, this is an inexpensive and quite easy method.....
Thing is you have to use a lube that doed not attract dirt or gum up....
WD flushes all that crap into the trans, prior to you dropping the fluid out of it....
LubIt8 is another good alternative, and it is in a "Pen" type dispenser, not a fast moving lube. but good quality....
Old 09-03-2006 | 10:51 PM
SportyPig's Avatar
SportyPig
Humm...guess I screwed up...already changed the tranny oil
Old 09-04-2006 | 12:58 PM
Hawg Dog's Avatar
Hawg Dog
I like to use BREAK FREE ! A great product for several uses . Can find it with the gun stuff at Wallmart .
Old 09-04-2006 | 08:06 PM
Tim's Avatar
Tim
My HD dealer turned me on to something called Lube it-8. Works great on everything. Tim
randazlr
06-26-2017 01:08 PM
GPHDXLC
05-15-2012 09:01 PM
tallboy56
06-10-2009 11:02 AM
Roadie09
06-08-2009 12:17 PM
KidFXDWG
09-10-2006 12:59 AM
Quick Reply: Clutch Cable Lube
