How do you clean your bike?
Since my bike is new, I have not had to do a lot yet, only 4000 miles on it.
But the bugs and dust build up, and I wet a soft cloth in a bucket with a very little soap in it, and wipe things down to get the bugs and dust off, then wax.
I don't like spraying water as it gets into things and takes a long time to dry.
For people with rims and spokes, water gets inside the rims and can sit for a long time, rusting things from the inside out.
I had bikes with very bad rust inside the rims.
If you do actually spray wash the bike, be sure to ride it an hour to dry it (somewhat) off, washing and parking it is sure to cause problems.
Yes, bikes are supposed to get wet, but I don't add to the problem if I can avoid it.
I have a friend who has a 2004 1200 and has never washed it.
35,000 miles and nothing but oil changes....
Brett
Brett
Obviously if any old car wash soap was ok for the flat paint, they wouldn't have recommended dish soap instead. If the manual takes the time to tell you to use dish soap, then that's what you should use, or windex, or pledge as other's have said. Just sayin!
Also, "never dull" works great on chrome parts.
Soap n water,,got three different size/shape soft brushes for the nooks n cranny's
when done washin a quick micro fiber towel dry then,,,
I Start the bike and let It "Warm Up" while I Blow dry it with the leaf blower.
Then Park it.
Start to finish,,, 45 minutes or so..
Steel wool Is good for the lower forks,,
A shinny nearly new U.S. Nickle will scrape the tar and boot goo off chrome pipes,,dry and no mess,,
Chrome Is harder than Nickle,,will not scratch so scrape away with Gusto.
BTW after every ride I wet micro fiber the bugs off,,some of their body acids will eat paint.
Then Park it.
