Tunable baffles on the cheap
I was told about a real cheap alternative to baffles that can be used on any non muffler type pipe that provides adequate backpressure to maintain the torque of baffles. Its very simple just drill a 1/4 in hole in the pipes about an inch or two from the opening. weld or JB weld the edge of washer thats about an inch wide to the dead of the bolt. Insert the blot and washer into the pipe and bolt in with a nut. By turning the washer to block the pipe opening it creates backpressure and torque without reducing sound hardly at all. You can tune them for the torque curve you want by adjusting how much the washer is blocking the pipe.
+1 this is the lollipop mod. If you check out Big City thunder Monster baffles they have been making tons of money on this cheap and simple mod for years... They charge like $80 for lollipop baffles that you can make in your garage for $10. The BCT baffles aren't even adjustable like the ones you could make.
I would braze the washers on instead of using glue.
Get a piece of all thread, or cut a bolt, cut a notch in it to fit the washer, braze it on.
Maybe slot the other end to fit a screw driver.
You can also get baffles and bend the tabs to get the amount of restriction you want.
I have them in my exhaust.
I bashed out the baffles of my stock silencers, but thought it was too loud and sounded a bit funky, plus I wanted some back pressure, so I jammed in some baffles out of my old Triumph. I removed the silencers, shoved them in, and did not even bother to bolt them in, wedge fit...
It was then too quiet so I bashed a long ratchet extention through the baffles bending the points over till it sounded good.
Brett
Brett
Use a Thumb Screw an get them at any hardware store.
http://www.bridgat.com/index.php?pag...humb_Screw.jpg
