Hey guys, i just bought another sporty after being out of the saddle for three months due to an accident and the back left turn signal does not work. The front left turn signal blinks but blinks faster than usual. Any suggestions on what might be the problem?
You didn't say that in the OP. Did you use the correct bulb types, dual element in front and single element in the rear? Your front is blinking faster than normal because the flasher (TSM in this case) doesn't see the rear bulb in the circuit. It pretty much works the same way as it does on other vehicles.
