DIY spray painting
Are you just going to lay down scallops on top of the stock paint, or do you plan on completely re-painting the tank and then adding scallops on top of the new paint? I would do the 2nd option, because it will look way better. If you are repainting the entire tank, I would get some sand paper and take it down to bare metal and then clean it really well with alcohol to make sure you get all the dust and dirt out of the metal's pores. Make sure you lay light colors before dark colors to keep the colors as close to their true shade as possible. For example if you want grey scallops with a black base, paint the tank grey and then tape off the scallops and then lay the black. Then I would suggest putting down some flat or matte clear on top to protect the new work.
i used an airbrush for the scallops. finer spray and more detailed.
the rest is rattle can.
this is a 2010 iron. i sanded the black base to rough it up and went to town with some black mettallic rustolem. $2.99 a can. let it dry, mask, paint, mask paint, used a proper automotive clear coat at $15 each. put a ton of layers on. wet sand and buff. people trip out that its spray paint. these pics are not a good showing of it. this was my first time painting anything like this. take your time and wait between coats. if you f up you can always sand it down and start over!
use this to clear it, it is a 2 stage clear in a can with self leveling... works awesome!!!!!! i use it all the time, hell i have shot paint out of the gun and used this to clear it!
![Icon Bike](https://www.hdforums.com/forum/images/smilies/icon_bike.gif)
sorry forgot the link to the 2 stage clear in a can
here it is
http://www.repaintsupply.com/pd_2_part_2k_aerosol.cfm
it is awesome awesome stuff i use it alot in the shop
here it is
electra_boogaloo
Powdercoat & Paint
07-25-2017 08:20 PM
