bike wont start
bike wont start
HAVE A 09 NIGHSTER WAS GOING TO RIDE TODAY WENT TO START TURNED KEY AND DISPLAY WINDOW SHOWS bus er can anyone help me out here and give me some guidance on whats going on fuel pump does its thing can hear it and all display icons stay on in display also already checked all fuses they were ok.
Com bus error usually means the ecm can't communicate with the other sensors and actuators.
Check all electrical connections for water or corrosion, as a last resort disconnect the ground wire from the battery for 30 seconds or so then reconnect and see if error goes away.
If it does'nt it could mean the ecm is bad, or at least needs to be hooked up to the factory diagnostic tester to see exactly what the problem is.
