Air shocks on, now have a question
Old 07-24-2010 | 12:13 PM
vermontrider's Avatar
vermontrider
Default Air shocks on, now have a question
I read where many have posted about installing Street Glide shocks on the Sportster to improve the ride, I got a pair on Ebay. The shocks are the Showa #54662-02A, 11 3/4 inch eye to eye. Installation was easy, used some washers to clear the belt guard, no other problems encountered.
My wife says the ride isn't much better than the stock shocks. Did we expect too much, or is there something wrong with the shock? We are running about 5 PSI, for a single rider about 130 lbs. Should we try less PSI? The shocks were shipped with caps, so I don't think there is a problem with oil. I guess I was expecting a more noticeable improvement. Sorry, no picture capability.
Any input is much appreciated - Thanks
Old 07-24-2010 | 12:52 PM
Gpsjr10's Avatar
Gpsjr10
I have 0 PSI in my shocks but I only ride solo and I am 220 lbs. It's not a huge difference to me but it is a noticable difference from stock.
Old 07-24-2010 | 12:53 PM
MechsHands's Avatar
MechsHands
with that light of a rider I would drop it to 0 psi. remember they are setup for a heavier bike.
I'm 230 and run 5-7 psi and up to 15 when the mrs gets on.
MH
Old 07-24-2010 | 01:04 PM
vermontrider
That will be what I try next, 0 PSI. No air i shock won't damage them will it? Thanks for the help.
Old 07-24-2010 | 01:36 PM
el campito's Avatar
el campito
Default air shocks
i have rk 13"
i had the same cuestion , runing 0 psi will hurt them?
no it will not and it is the most confortable
this shocks are made for a heavier bike
it is a lot of diference
i ride 0 psi 2up bags full of beer and it is fine
Old 07-24-2010 | 02:26 PM
1HD1C's Avatar
1HD1C
just did this myself and did what certainteed said to do.
left the guts out of the shocks had my son who is
i just found out today 25lbs heavier than me sit on the bike
and then i stuck the guts back in.
so thats 0lbs possibly a vaccum created if thats possible and the bike
rides like a dream.
Old 07-24-2010 | 09:32 PM
xFreebirdx's Avatar
xFreebirdx
Keep in mind that the air pressure is for rebound ONLY. The preload is preset for the weight of the bagger you got them off. Mine are off an 97 Ultra and preloaded at about 720lbs.
Bleeding the shocks as mentioned above is a great idea.
I run 0psi in my shocks and its a hundred percent improvement over stock. Whether I'm riding solo or 2 up.
foxtrapper
01-20-2023 12:12 PM
EdandGrace
08-17-2013 08:46 PM
Smitty79
08-08-2013 01:55 PM
blarg
06-19-2012 04:07 PM
onadraw
07-19-2009 02:25 PM
Quick Reply: Air shocks on, now have a question
