Releiving the combustion chamber
Old 07-23-2010 | 11:14 AM
Rink-A-Dink's Avatar
Rink-A-Dink
Originally Posted by Flatlander
If you use stock 883 heads with the conversion kit you will have to have them machined. Basically cut some material out of the inside of them to get the correct compression ratio and or cylinder head/valve to piston clearance. Whereas if you use 1200cc heads or the pistons they are advertising everything will bolt up.
What is the correct compression ratio? Meaning a static ratio?
Old 07-23-2010 | 11:35 AM
Rink-A-Dink
Originally Posted by guitarman023
lol yeah me too, mine's running about 12.1, it barely runs on 92-93, and I'm playing with the timing a lot. It's a helluva ride though!
I'm in Utah at a high altitude. Generally, with my Solex carbed BMW which is a 10.5:1 compression and has a recommened 91 + octane rating for fuel. Have found as have others that at higer altitude we can get away with an 87 octane rating without pre-det.
With the altitude factor in mind, what would the the optimal compression ratio for me Sporty?
Old 07-23-2010 | 02:21 PM
Rink-A-Dink
Came across a well written article on www.harley-riders-guide.com/harley-davidson-compression.html .
Thought I would give it a share. And thanks www.harley-riders-guide for such a wonderful, informative article.
Old 07-23-2010 | 03:36 PM
WDHGS's Avatar
WDHGS
check out this site, it will explain a lot of what you are looking for: http://www.nrhsperformance.com Dan has done incredible things with stock 883 engines to get them to outperform 1200 models.
Old 07-23-2010 | 05:54 PM
Rink-A-Dink
Thanks but doing a vanilla conversion, they are a little to "upscale" for me. Just want a solid understanding of what is going on, they do provide useful information geared for their product and services although if you want to go that direction.
Gregory Amundson
Engine Mechanical Topics
08-07-2018 06:13 AM
Dudepants
03-04-2018 03:52 PM
Ben D
09-15-2017 05:33 AM
RidemyEVO
07-15-2013 07:08 AM
bullelkklr
EVO
02-26-2009 04:27 PM
Quick Reply: Releiving the combustion chamber
