Sportster Oil Filter
Old 07-17-2010, 09:17 PM
Dawiz's Avatar
Dawiz
Dawiz is offline
Default Sportster Oil Filter
I have a 2005 1200C Sportster and went to get an oil filter. I have always used HD Part No. 63796-77A since I bought it new. The parts guy gave me a 63798-99A which is the same filter that fits my RKC. I questioned him and he said that they were the same. Any suggestions?
Old 07-17-2010, 09:28 PM
shiftharder's Avatar
shiftharder
shiftharder is offline
One may be a larger filter - holds more oil - better cooling.
Old 07-17-2010, 09:32 PM
MechsHands's Avatar
MechsHands
MechsHands is offline
search for it and you will see many discussions on this. The search feature is your friend.
Charley has reccomended using 63813-90T's many times. It is about twice as long as the normal filter.
Its likely filter that was suggested is the same way.
MH
Old 07-17-2010, 09:50 PM
cHarley's Avatar
cHarley
cHarley is offline
The filter they gave you (63798-99A) is a 5 micron TC filter.
The correct filter for an EVO is 30 micron. For the Sporty, that would be the standard 63796-77A or the extended capacity 63813-90T.
Old 07-17-2010, 10:29 PM
Dawiz's Avatar
Dawiz
Dawiz is offline
Found this on another web site. According to this it will work as an upgrade.
Thanks for the help.
roduct ID: 63798-99A
Genuine Harley-Davidson® Oil Filters - Chrome
Check for Fitment Details
Harley-Davidson is taking the lead in the industry with this breakthrough filter. It uses a synthetic media that provides nominal 10 micron filtration with increased retained capacity for dust, soot and other solid matter. Low internal pressure drop Integral Pressure Relief Valve, Integral Anti-Drain Back Valve. Available in chrome or black, this is the best filtration available and will retrofit to most earlier models.
SuperPremium™ Oil Filter
Chrome.
Fits all '99-later Twin Cam and Evolution® 1340-equipped models and available as an upgrade for any motorcycle currently using P/N 63796-77A or 63805-80A. Made in the U.S.A.
Old 07-17-2010, 10:47 PM
OldFenderGuy's Avatar
OldFenderGuy
OldFenderGuy is offline
I won't use a 5 micron filter on my TC engines, let alone my EVO and EVO Based engines..
Old 07-18-2010, 09:55 AM
Dawiz's Avatar
Dawiz
Dawiz is offline
What do you suggest?
Old 07-18-2010, 10:00 AM
cHarley's Avatar
cHarley
cHarley is offline
I suggest using the correct 30 micron filter. That would be the standard 63796-77A or the extended capacity 63813-90T.
The fact that the -99A "fits", doesn't make it the correct filter for an EVO.
Old 07-18-2010, 10:19 AM
Dawiz's Avatar
Dawiz
Dawiz is offline
I have always used the 63796-77A in the past. This is the first time I have been given this filter for the sporty. I questioned the parts guy, but you know how that goes. I am going to take it back and swap it.
Thanks
Old 07-18-2010, 11:11 AM
xwhyz1959's Avatar
xwhyz1959
xwhyz1959 is online now
Received 1,722 Likes on 521 Posts
[quote=OldFenderGuy;7015861]I won't use a 5 micron filter on my TC engines, let alone my EVO and EVO Based engines..
Same here!!
Quick Reply: Sportster Oil Filter
