Sportster Oil Filter
Old 07-18-2010, 11:29 AM
OldFenderGuy's Avatar
OldFenderGuy
OldFenderGuy is offline
Originally Posted by Dawiz
What do you suggest?
Old 07-18-2010, 09:43 PM
Ric27's Avatar
Ric27
Ric27 is offline
I need to get on the forum more often. I miss far to much when I don't. I went down to the dealership last week and asked the parts guy for two oil filters for my Sportster. What I got was part No. 63805-80A. On a short search I was not able to find out what the Micron rating is on this filter, only that it fit just about every HD made sense WWII.
Anyone know about this filter?
Old 07-18-2010, 11:00 PM
OldFenderGuy
PN 63805-80A should be the 'Black' version of the Chrome 30-micron 63796-77A filter shown in the above picture.
It's made for the EVO and EVO based engines, and the "official description" is;
"Fits '80 to '98 FLT, FLHT, FLHR, '82 to '94 FXR, '84 to '98 Softails, '84 to '95 FXRP, FLHTP, '84 and later XL, and '08 and later XR models."
Old 07-19-2010, 05:35 AM
Jehu's Avatar
Jehu
Jehu is offline
Received 1,114 Likes on 626 Posts
for a 21 Micron alternative you can use these from Wix:
Part Number: 51215
UPC Number: 765809512153
Principal Application: Buell, Harley-Davidson Motorcycles, Dixie Chopper (For chrome version, use 51225)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Burst Pressure-PSI: 325
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Old 07-19-2010, 05:42 AM
Jehu's Avatar
Jehu
Jehu is offline
Notwithstanding my post immediately above, I have actually been using these for years and, other than the burst pressure rating, appears to be of identical specification.
Part Number: 51348
UPC Number: 765809513488
Principal Application: Various Chrysler/Jeep (82-10), Various GM, Saturn (85-07), Lexus (90-10), Saab (67-09), Suzuki (86-02), Toyota (88-10), Ford (03-10), Mazda, Mercury (05-10), Yugo (86-89), Various Lawn&Garden, Farm Equip.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Thread Size: 3/4-16
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=21/37
Burst Pressure-PSI: 275
Old 07-19-2010, 07:00 AM
DaytonaSportster's Avatar
DaytonaSportster
DaytonaSportster is offline
Check this one out I just found on Ebay...
http://cgi.ebay.com/ebaymotors/Harle...item23087baf0e
Reusable - FLO Reusable Stainless Steel Oil Filter by PC Racing #PCS4C
The outer housing is polished billet aluminum
Fits most Harley Davidson motorcycles.
I challenge you to find a better oil filter than this beauty. This reusable oil filter is made from laser cut, medical grade, 304 stainless steel micronic filter cloth. In addition to filtering down to 35 microns, this high tech filter technology maintains consistent flow under all conditions including extreme heat (up to 600 degrees), the presence of water, and cold start-ups. This filter has magnetic pre-filtering, a progressive rate bypass valve, a drilled wrench nut for easy removal and for safety wiring required at most race tracks. All this encased in a beautiful polished billet alluminum housing that doubles as an oil cooler. FLO Oil Filters will save the average user hundreds of dollars and valuable time, by simply using this one filter for the life of your motorcycle or ATV. The "turn lock" design allows for easy disassembly for cleaning of the filter element. This also allows for easy inspection of the trapped particles, so you know what is going on in your engine. The filter element can be cleaned with solvent, contact/brake cleaner, kerosene, or any other degreasing agent; even common dish soap.
This high tech filter technology is widely used in all types of auto racing including NASCAR, Indy type cars, Formula 1 and in the Aerospace industry where filtration is of the utmost importance. Now you can have this technology in your motorcycle, ATV, or UTV. I have a complete line of FLO stainless steel oil filters by PC Racing including "drop in" filters so send me an email if you can't find one for you, as I likely have it.
Applications: Part #PCS4C
Harley Davidson #PCS4C
Dyna Evo 91-98 Dyna Twin Cam 99-10
Softail Evo 84-99 Softail Twin Cam 00-10
Sportster 85-10
Touring Evo 82-98 Touring Twin Cam 99-10
Old 07-19-2010, 07:48 AM
cHarley's Avatar
cHarley
cHarley is offline
Great, except for the initial cost of the filter and all the time and mess involved in cleaning it every time you change your oil. I'd rather just spend $8 for a new filter. At 5,000 miles per oil change, you'd have to use it for 65,000 miles just to break even on the initial cost of the filter.
Old 07-20-2010, 05:27 AM
xwhyz1959's Avatar
xwhyz1959
xwhyz1959 is online now
Received 1,744 Likes on 524 Posts
Old 07-20-2010, 06:12 AM
cHarley's Avatar
cHarley
cHarley is offline
Originally Posted by xwhyz1959
That Pure Power you listed is even a worse pay back. At $199.95 +shipping, and a 5,000 mile oil change interval, that's 25 oil changes, or 125,000 miles just to break even on the price of a filter. Not even counting the wasted time and mess cleaning it at each oil change.
mirrorman
Oil Archive (no new posts)
03-19-2016 12:08 PM
P51Driver
11-22-2012 10:43 PM
shawnsimon
11-13-2010 01:13 AM
ezryder1962
04-27-2009 11:53 AM
1sportytrike
10-10-2007 09:34 AM
Quick Reply: Sportster Oil Filter
