2009 XL1200C Battery Cover
Old 07-16-2010, 11:07 PM
Foodog's Avatar
Foodog
Foodog is offline
Default 2009 XL1200C Battery Cover
My son wanted a bike for his wife and got a deal on an 09 1200. He also rides it back and forth to work rather than his Ultra. Anyhow, we were out for a short ride today and the battery cover kept coming open. Got home, took the seat off and found two really cheap plastic clips that barely hold the cover closed. Anybody else find this to be a problem and is there a fix?
Old 07-16-2010, 11:11 PM
WDHGS's Avatar
WDHGS
WDHGS is offline
Yes, this has been a common problem for Sportster battery covers. A few guys have come up with different ways to mod the covers and then run a zip tie through them to ensure it doesn't come off. The dealer fix is usually a set of new clips which run about $40, but if the bike is under warranty still it should be covered. In '10 they actually have a slot near the top where you can run a zip tie straight through it and onto the frame. Search in the Sportster forums for "battery cover fell off" and you'll find a slew of pics from guys who have lost and later recovered theirs on the highways with a little road rash...along with their suggestions and fixes. Glad you caught it now!
https://www.hdforums.com/forum/sport...-fell-off.html
Old 07-16-2010, 11:34 PM
Foodog's Avatar
Foodog
Foodog is offline
Thanks 09. Fix seems relatively simple. I'm surprised that Harley would put something this cheap on a bike and continue to use it after it's a proven problem.
Old 07-17-2010, 04:51 AM
MechsHands's Avatar
MechsHands
MechsHands is offline
I actually bought some of the new clips, didn't like them and couldn't run the zip tie through it. Went back to the old number and couldn't be happier. Drill a hole through the clip drop the zip tie through and voila.
MH
Old 07-17-2010, 06:34 AM
diablo666's Avatar
diablo666
diablo666 is offline
I don't even have clips.I just zip tied mine on.You don't need to open the cover unless you need a battery or to install a pig tail for a battery tender.If the battery needs charged you can do that at the battery cable on the starter and any metal part of the bike.
Old 07-17-2010, 06:52 AM
JayStronghawk's Avatar
JayStronghawk
JayStronghawk is offline
Since 04, Battery covers have been flying down the road ...
Old 07-17-2010, 08:57 AM
shiftharder's Avatar
shiftharder
shiftharder is offline
Same happened to my 2008 1200 Custom - the first year - I now use tie raps too but because of relay issues with the Sporty (water getting in the fuse area) I now carry a box cutter and spare tie raps in my tool pouch in case of a break down on the road - and yes, I carry a spare relay too!!!!
Old 07-17-2010, 12:07 PM
Cazimere's Avatar
Cazimere
Cazimere is offline
I put a screw in the front tab to keep it from being pushed through the frame and dropping down in front of the battery (already happened) and a 14" zip tie with lots of slack, so i can still open the cover without cutting the tie.
Attached Thumbnails 2009 XL1200C Battery Cover-img_8899.jpg   2009 XL1200C Battery Cover-img_8923.jpg
Old 07-17-2010, 12:42 PM
WDHGS's Avatar
WDHGS
WDHGS is offline
I'm guessing that the moco has recognized it's an issue since on my '10 there is a pre-drilled open slot in the top left of the tank cover, which fits perfectly for a zip tie.
Old 07-17-2010, 09:40 PM
MechsHands's Avatar
MechsHands
I'm assuming you mean the battery cover not the tank cover correct?
The slot is nothing new. My 06 has it. Not sure how far back it goes.
MH
Quick Reply: 2009 XL1200C Battery Cover
