48 speedo bracket mounted
Ok after months of back order I finaly got the 48 speedo bracket and now have it installed. Had a buddy CNC the thing and still had do do a little dremel work before it fit. Next I will mount my stock hub to my new 16"x3" rim and install a 120x16 front tire and this winter will be a mid-glide front end conversion
Here is a shot of how much had to be ground for it to fit
Here it is on the bike
Here are a few shots of the bike before this summer
Before I started any of the latest mods
After the seat, rear fender ECM relocation and headlight
TEXASportster (07-31-2021)
The risers on the stock xl are flared out at the ends in somewhat of an L shape and the 48 clamp/speedo bracket is made to slip over the 48 risers and they are n ot the same shape so you either have to carve out material so the risers will slip over the non 48 risers or machine the risers to fit into the bracket. leave it to HD why in the world would they keep a common fit so you could just buy the clapo and bolt it on
Scuba--here's a bird's eye of mine. Keep in mind I have 3.5" risers to cover the clearance needed for the stock headlight/h. hood, while fd2blk has changed out the headlight/hood and connection and the speedo mount can and does sit much lower.
brendajmull
08-27-2006 05:40 PM
