883Low Question
I see a lot of talk about the sportster being top heavy, but I've never noticed. Now I am sure this is because the only thing I've ever driven is my Nightster so I don't have anything to compare to. You just have to see what feels right to you. As soon as I sat on my bike at the dealer I knew it fit me perfect.
I have ridden all sorts of bikes, and don't notice the sportster being top heavy.
I have the 1200 low with the 4.5 gallon tank.
It IS ponderious coming off a 350 LB 1969 Triumph Daytona, which felt like a bicycle almost.
But to me, it just feels heavier (its 200 pounds heavier), not top heavy, and I have raised the bike up from stock quite a bit.
I one foot it even two up without problems.
( I never put both feet down when sober)
Brett
Brett
The comparison is between a Sportster, where you sit high above the bike, and a Big Twin (Like a Dyna or Soft-tail), where you sit lower down, almost in the bike.
You're looking at two different frame geometries. The Sportster frame is more like the standard bikes that we had back in the 70s and 80s. Bikes like the Triumphs, CB750s, GS750s, and such. It's narrow and tall. The Big Twins, for the most part have frames that are wider and lower. Plus, the larger engine keeps more weight lower to the ground.
It really is what you're used to. If all you've ever ridden was newer American style cruiser bikes, including the Japanese copies, then the Sporty feels top heavy. If you're coming off sportbikes, sport-tourers or dirt-bikes, it won't.
fastmofo01
05-27-2014 05:55 PM
