OHH BOY, here we go AGAIN!!!!!
#31
if they are the same part number cant i just swap them and see what the resoults are?
i mean if the starter starts acting up then i know i have a bad relay if not then there is something
else going on in the charging system.
i know some of you guys have mentioned possible stater but wouldnt this do it all the time????
this acts like something is getting hot then causing a problem as it doesnt do it when the bike is cold.
Also someone asked about the battery connections, i checked all plugs and connections before it
went to the shop last week and they were all tight.
#32
#33
#34
Changing out the Voltage Regulator is easy as I did it in 5 minutes and I'm no wrench believe Me. I am keeping the stock as a spare as I already needed to replace the stator on a 06 Sportster. Look for bargins on EBAY, I got My chrome on from a canadian H-D dealer on EBAY for about $40 shipped if I recall . I'm sure it would cost about a Hundred Dollars ( H-D ) at the dealership......WVleo
#35
i found the part number for the regulator, from what i have been able to ascertain the only interchange is 08/09. it did not mention the 07 or 10 as being the same regulator
last night i went out and swapped the relay's around for wishful thinking purposes.
when the problem first started nearly 2 weeks ago and before i took it in the first time i had pulled the side cover and found that the fuses already had dielectric grease.
when i pulled the relays out last night the starter relay looked nice and clean but one of the pins on the main system relay had some green on it and looked like it had been cleaned greased and reinstalled.
i switched them just to see what will happen but I'm still feeling the effects from the
3 shots in my neck 2 days ago and had to use my truck for work today. hopefully tomorrow i can ride it and see what happens.
from seeing some corrosion on the pin i suppose it could be the problem and that even though they had cleaned it before i bought it may have become internally damaged.
thoughts?????
thoughts?????
#36
#37
#38
well today my neck felt good enough to ride it to work and wonder of wonders when i hit the starter button to leave my garage it cranked really weird, i don't want to jump the gun here but was that just a coincidence or is it because the system relay is now the starter relay
and vice versa.
no check engine battery light yet either but i need to run it more.
i also figured out a way to carry my ohmeter just in case then i can at least test whether the battery is getting anything from the charging system if it does come on again.
we are going on a run tomorrow in PA and then stopping at Bryans Harley
in Langhorne for their 25th anniversary, figure if it runs good with no problems i will buy 2 relay's and replace both in the fuse box.
#39
UPDATE-----relay was wishful thinking, seems to only do it when it is good and hot.
rode it home and the light came on as i parked behind my garage, grabbed my ohmeter real quick and connected it to the tender connection had 11.5 at idle
and would only go to 12 when i throttled the engine.
i set the friction screw to where i thought 2500 should be and tested, it
was at 12.6-7 and then bang it went up to 13.8-9 and the battery light went out
seriously leaning towards voltage regulator.
opinions? and any suggestions how i should get them to replace it or should i just
chance it and buy one on my own and if it does it then write to MA HARLEY to try
and get my money back?
