OHH BOY, here we go AGAIN!!!!!
the bike is a 2009 nightster that i bought exactly 2 months ago.
i dont have a service manual yet but in my owners manual it shows
a system relay in the fuse box, is this the relay you are talking about?
if so any idea how much they cost. if its cheap enough i will just go
buy one and pop it in to see what happens.
thanks
thanks
you cant' miss them. about 1/2 inch by 3/4 inch black rectangluar plastic things. the back of your cover should have a scamatic diagram telling you what is what too. if you pull them out and they are corroded you need to clean that crap out of the fuse blockand pak it full, really full, with dialetic grease then install the newones.
i mean if the starter starts acting up then i know i have a bad relay if not then there is something
else going on in the charging system.
i know some of you guys have mentioned possible stater but wouldnt this do it all the time????
this acts like something is getting hot then causing a problem as it doesnt do it when the bike is cold.
Also someone asked about the battery connections, i checked all plugs and connections before it
went to the shop last week and they were all tight.
I'm sure it is too but trying to get this ****ing Harley dealer to do anything without it being completely gone is like beating my head against a brick wall.
they say if they replace it and it tests good back at Harley then they don't get reimbursed and I'm at the point to where i will buy one and throw it on myself as i cant afford to get stuck and then have to wait for a tow truck especially if I'm on the road to VA and it happens it will completely ruin my trip and may cause a brick to get tossed through someones front window
if anyone can tell me what year range fits/part numbers or if someone has an original one reasonable that they swapped out for a chrome please PM me.
id take it up with the service manager...if he's not available then i would take it up with the owner of the damn stealership...or take it to an indy shop and have them find the problem and then take your bike back to the dealer and show them that there is something wrong with it and they are being lazy *** holes.
with the way i feel right now i probably wont be able to ride for another day or so or i would take a chance and ride it down there and make a commotion on the sales floor about it.
if i take it to the only indy shop thats in my area i will have to pay out of pocket for the diagnostic work which could take a few hours and a few hundred dollars and then end up eating that even if they find a problem,
im sure Harley wont reimburse me for that since the bike is supposedly under a warranty.
of course they wont. it should only cost about $50 bucks to do a diagnostic check. and the regulator is not a huge fix. if it was the stator then yea thats a problem. but the regulator from what i understand is not a hard thing to fix so even if you pay outta pocked it shouldnt be too outrageous.
again if anyone has the proper part numbers for this part i would appreciate it as I'm getting no where on the web
also if you have swapped out your original for a chrome one let me know what you want for the original.
thanks
