Lets see you 48's..
#1551
Received 4,228 Likes
I used your dk customs handlebar clamp. I had an issue with the length of the clamp bolts. The top 2 aren't long enough when used with your indicator bracket and stand-offs because I am using 2 inch Loner Industries risers. I just installed the clamp with the risers, then used double sided tape and a zip tie to hold the bracket.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
#1552
Holy that clutch lever must be a b!tch to pull in!
Also looks like your fork tubes are set at different heights? Wanna make sure they're the same.... If I recall, factory specs is: top of the fork cap should be around 10-13mm above the top tree.
Bike looks good though, I'm in Fort Sask... I also have my 48 in pieces, gotta love winter mods!
#1553
Yeah sure would be nice to have somewhere warm to wrench, but winters awesome for mods, especially when it's like 7 months long
#1555
No I didn't change the top tree. The risers are shaped to fit with the stock trees,and I was unsuccessful in finding the right length bolt to work. So temp fix was to use the tape and zip tie. Still trying to figure out a solution. But for now it works.
#1558
It's really nice right now but we'll see how my hand feels after a full day out haha, and **** your right thanks man ill check that out tomorrow. Weird cause ive never touched the forks...
Make sure those pinch polts are torqued to spec as well, If I recall they should be around 30-35 ft-lbs.
#1559
The 48's came from factory with the turn signals bolted to the upper tree... I see your's are bolted to the lower. Someone at some point would of had to unbolt the fork pinch bolts to switch them around.
#1560
Let me know what length bolts you need, I'll get some and send them your way.
Kevin@DKCustomProducts.com
