Does anyone know where I can find an extended rear axel to fit a 05 sportster? I got a side mount license plate designed to mount onto the axle but the stock one just isn't long enough...
I've dealt with those a couple of times...your plate mount should have a spacer with it to mount it to the lower shock bolt. If not you can make one pretty cheap. Probably alot cheaper than a longer axle.
