Sundowner Install
if it's what i think it is and you are switching from the solo seat to the two up, the washers has a clip on the top side of the fender you slide off then the threaded piece comes off from the underside. just move it back to the rear hole in the fender the same way and secure it with the clip. It's really easy if it's what I think it is.
Take the washer out of the current hole for the solo seat, remove the plastic plug that is on the rear fender behind the current place the solo seat was screwed into. Place that plastic plug in the hole you just removed the washer from. Install washer in the rear hole you just removed the plastic plug from.
Quick Tip: The last step is easier if you use a cable tie to help get the washer in place.
Sure, it's all a matter of opinion, but I went back to the OEM once (as I think it looks tons better) and I couldn't take it. Ugly as all hell, but I think it is comfy, and most agree.
