Please help!- Loss of power.
First of all, this is my first post here and I'm sorry it is going to be a long one.
I bought my bike last week and it was running perfectly and now not so much.
The bike- 2008 Nightster, 1900 miles, rush slip ons, big sucker, power commander 5 from Fuel Moto. Bike is clean as a whistle.
I had been taking some very short trips from home to work, so it is hard for me to remember exactly what preceded the loss of power. It happend shortly after my first fill up. I did use 91 octane. Also, right after the fillup i got denched by rain. Some day after that the bike started popping bad on deceleration and power was down. It would shutter a bit a low rpms.
I thought it could be plugs so i changed them (but didnt gap them). No change. I thought it could be gas cap venting because i screwed the gas cap down way too tight since it was sitting up high. Rode with it loose and no change.
So I drained the tank, put in seafoam, put in 93 octane gas and it seemed to have eliminated the backfiring but power seemed even worse- horrible in fact. I probably rode it 8 miles because i was pushed for time so that may not have been long enough.
So my plan for tonight is to gap the plug or even swap back the old ones- they looked fine. Any other ideas to try?
I changed the plugs back to the old ones because they are fine. I rode it 20 miles and no real change. Next step is to check for water in the intake and fuse panel. I will also try to pull the fault codes. If these don't work i am going to remove the power commander and use the oem settings- just to see if it makes a difference.
It drives like it is partially starved for fuel, air or spark (duh), just don't know which one.
