V&H sideshots baffles??
How do you like the sound with the quiet baffles in? Notice any difference? Does it sound better at lower RPM's?
I just put the quiet baffles in my short shots, same exact thing i think. the quiet ones have a solid end cap on the end inside the pipe whereas the regular ones are straight through, just stick something thin in there and if it hits a solid end about 10" in they're quiet.
I had sideshots with quiet baffles for about a day. The only difference in sound that I noticed was when I accelerated it sounded like I had a corn cob stuck up the end of the pipe. At idle they sounded the exact same as with the standard baffle. The V&H website says something about the quiet baffle only lowers the sideshots and shortshots by 3-4 dB. The are both around 95dB with the standard baffle. So they keep the pipes still way over the EPA legal 80 dB point. I also noticed a severe decrease in performance after recalibrating my fuelpak to the settings with the quiet baffles.
I was told no recalibrating necessary. It seemed odd to me considered the obviously decrease in air flow with the solid end caps. I might get a tad more popping, but everything else is pretty close. Definitely changed the sound, and made them noticeably quieter. I like them more just because they are quieter, but my wife liked it the old way.
The biggest pain in the *** with the whole thing is that ridiculously long bolt going through the pipe in a really tough place to get it out, it took forever on the lower pipe. ended up cutting the bolt to probably around 1/2 an inch. no reason for it to cros the whole diameter of the pipe.
