A quick question about rocker gaskets, am I missing a gasket here?
Enclosed is the picture of one level of my rocker. I only see one seal, where two could go, one on each side. Only two came in my set, one for each head. So do I just replace the one I have, or does two go on each head? It seems like these would restrict the oil return flow, but is that their purpose?
Thanx, I am trying to button up one side tonight. Randy D.
Randy, I hope you don't mind if I follow along here. I came home from a 65 mile ride yesterday and there was a thin coating of oil on the clutch housing. I thought the clutch cover gasket had started to leak. Then I discovered oil on the left battery cover tin and on the left side of the rear wheel. Its comming from the left side of the rear cylinder rocker box. Bummer. Seems to happen a lot on here.
The assembly is not complicated. I was intimidated to begin with, but just jumped in feet first. I was surprised the hex bolts, 1/2" were not very tight. The allen bolts WERE tight. There are 4 bolts on the top cover, 4 hold the rocker arms, then 3 hex and 2 allen on the lower cover.
I need to see if these are the "umbrella" seals that I read others talking about.
There is a place for 2 seals, but only one was on the first rocker setup, and only 2 in the whole kit, which should be one for each side. I just want to make sure I do this right, I don't like to go back.
Thanx for the help, Randy D.
Only one umbrella valve per rocker. The umbrella goes over the breather bolt/intake side of the head. Without it, or with it on the wrong side, you'll be puking out oil out of the breathers. I learned that the hard way after the first time I changed my lower rocker gaskets, as I didn't pay attention when I put them back on.
The front cylinder was easy, but the rear is a nightmare. I was beginning to think the motor had to come out of the frame to get the covers off. You have to turn them 90* then go straight out. The rear center 11mm bolt is a real biatch. So if anyone is debating this, yes, it can be done with ordinary hand tools. But it will take a little while, and you must have patience.
Tools:
3/16 allen wrench, either cut down real short or the type with the ball on the end.
11mm socket
1/2" 6 corner socket, or metric equivalent (12mm or 12 mm maybe) 1/4" ratchet size.
1/4" swivel and extensions
Tools:
11mm socket
