HELP! My sportster won't "pick up" when hot.
Wow. Thank you so much. ! will check it out right now. Cheers.
Can anyone out there help me? I work in a bike shop in London and my best mecahanics are scratching their heads on this one. My 2005 sportster has begun to stutter when trying to pull away at lights and junctions etc. It only happens when warm (after 2 or 3 miles). I have checked the coil (I swapped with a collegue), plugs, cleaned the carb and replaced the carb inlet seals. Could it be the crank position censor? Is this an expensive fix?
FISTInc
Electrical/Lighting/Alarm
04-16-2011 12:50 PM
tcataldo
12-24-2010 11:47 AM
