Nightster wonīt start...
Well if the lights would dim when I press the starter button itīs probably not that. I had some 2032 batteries and replaced the one in the fob, no luck. I talked to the guys I bought if from and they said that the lights wouldnīt dim even if the battery was bad (was talking about a bad cell). Gettinī a new after the weekend and keeping my fingers crossed. Feels sad to have to have to repair it after only 450 km. Itīs probably/hopefully something minor.
In regards to the lights dimming, mine did I looked at it to purchase. The battery was dead and didn't have enough to power the lights and the starter solenoid.
The easiest thing to check is to put a voltmeter on the battery and see what it's reading. You can pick one up at Radio Shack for around $10.00.
If nothing happens when you press the starter it could be the fuse or solenoid on the starter but I doubt it's either. Most likely it is a dead battery.
You will probably need one anyways, but you should pick up a small trickle charger or one of those battery tenders some of the guys here are talking about.
The clock however, is independent from the bike's computer system and memory and like a wristwatch, would run for years on nothing larger than a watch battery.
Bike in Gear? Try the simple things first.
(I only suggest this because I have solved other threads with this simple solution).
scrname321
13
05-11-2009 10:46 AM
