Tool to fill forks without removing endcaps
I've seen these for other bikes but not for a Harley. Basically a syringe & rubber tube with a hollow screw that will screw into the drainplug that you can shoot the oil into the forks after loosening but not removing the endcaps.
Anybody have one of these?
You could always put a bleeder valve in there, and inject it with a hose and syringe then close it so you don't loose any fluid. There is a replacement-style bleeder valve that has the seat included. The seat is 1/8 NTP, so it would have to be drilled and tapped for that. See the 'HELP' section at the auto parts store.
+1 - You have to loosen/remove the fork cap nuts anyway to vent the pressure in order to both drain and refill the fluid.
I dont get it.
Most people never change the fork oil on a bike unless changing the weight, plus it only takes about 15 minutes to drain the oil and refill by removing the fork caps.
I remove the caps, then remove the drain screws, let the oil drain (no pumping of the forks) then refill.
If you want it real easy, and a better ride, the progressive springs make it easy to put the caps back on with just a regular socket.
I think it would be more trouble playing with pumps and hoses, the only thing that saves you is having to remove the caps all the way, which is no big deal.
Brett
Brett
