Any have a Kuryakyn Hypercharger Air Cleaner?
While the Hypercharger has the appearance of a "Ram Air" scoop, there is an exhaust hole on the backside, rear of the unit which prevents any "ram air" action. If fact, at highway speeds, air flows in the front and out the rear hole, actually creating a negative air pressure across the carb/throttle body intake which literally sucks air away from the intake. That's the last thing you want if your looking for a performance improvement.
While the Hypercharger may "look OK" on a dyno, a dyno doesn't have the ability to recreate what happens at highway speeds when you have air being forced into the front of the unit and then sucked out the back, resulting in the loss of intake air.
The NRHS Hurricane Flow, Big Sucker, HD Heavy Breather, and even the plastic SE A/C, are better performing units.
While the Hypercharger may "look OK" on a dyno, a dyno doesn't have the ability to recreate what happens at highway speeds when you have air being forced into the front of the unit and then sucked out the back, creating a loss of intake air.
+1
Jinx......You owe me a Joint.
