L.E.D. stop, run, turn?
ok, looks like im flying solo on this mod so heres the objective
1. tuck under fender so its nearly invisible.
2. Must be bright enough so the cage on my *** is fully aware I am stopping / turning
3 not look like its a hack job (I have seen ricers do it and the L.E.D's were not straight or are to big and spaced out to far)
I am going to order the led bar and try to mold fiber optics into clear epoxy to the exact curve of the rear fender so the light blends to a solid light bar at the end of the fender while the fiber optics should keep the red break and the amber turn separated (that's the plan at least)
I will keep this thread going with the results and photos through the process.
