I'm not a big fan of bras on bikes or cars. They do more damage than good. Bought the wifes sporty that had a bra on it. First thing i did was pull the thing off and the tank has marks where the seams are on the bra rubbing the tank. Previous owner had the right idea, because the seat really rubs the back of the tank. So, I guess you have to take the lessor of two evils.
I think it comes down to how clean you keep your bike and if you remove the bra when you wash it.
It surely could trap dirt inside and cause some nasty scratches but if you take extra care of your bike I'm sure it could be prevented.
IMO, that's probably true if you ride the bike once a week to the local watering hole and back, and then wash the bike when you get home.
If you ride frequently and wash the bike every couple of weeks, then the bra will damage the finish. The bra is also a bit of a pain in the **** to put on and take off, which eventually will lead to it not being done and damage will likely be the result.
I was thinking that I might get closer to the tank with the drag bar, increasing the risk of scratching it. The new handle bar isn´t installed yet so I don´t know if I in fact will. I´m driving my bike at least every day and will wash it every other week so for me it seems a bra might not be a good idea.
Holy crap! wash a bike every 2 weeks. I'm lucky if i wash mine 3 times a year. But when I clean it up its about a 3 hour ordeal. I'm old school, I would rather ride than clean.
Getting me a drag bar to my Nightster and I´m afraid to scratch the tank. Is a tank bra a good idea? I have looked around a little bit and some say it does more damage than good. What are you opinions? Where can I by one? Any of you have pics? I think it looks good on the Nightster.
Thanks
I depends on how wide you are and if you wear coats with zippers. Any type of a bra has to be removed regularly and cleaned under and you have to keep it well waxed and you also need to remove them if they get wet.
Bras will help but you can't just put it on and forget it like so many people do.
