Enricher/Choke cable replacement help
Just need a little info on the procedure to replace said cable and ****. Is it easier to pull the tank then air filter assembly? Or another way that is easier. Wife bought a 2004 883, as we all know by now, these d@%m ***** are the first thing to go. Maybe a replacement **** instead of a cover, just have not found anything she really likes that doesn't require the OEM **** to be in place. Thanks for suggestions, ideas, dreams, etc.
+1 on what cHarley said. You just need to pull the carb to get at the spot where the cable connects to /screws into the carb. As for the "these d@%m ***** are the first thing to go", I'm not sure what you're talking about......I've never had an issue with the *****, and I'm only on my second cable in 10 years. I had to replace the original cable because I over tightened the mounting nut causing the plastic portion of the mount to break. If you just need to replace the ****, you could always find something you like, drill two holes (a hole in the back side for the pin & one on the side), tap the hole on the side for a set screw, and there you have a new ****.
WV seems like every Sporty we looked at and have talked to owners of have had problems with the stock plastic **** coming off the cable end coupler. Not bashing anything, just thought that Moco would have made something like that a little heavier weight. Thanks for the idea on the new ****.
I didn't remove the carb or the tank. I did separate the carb fron the intake but didn't undo anything, Simply unfasten the choke end, separate the intake / carb the cables hold it in place and remove the choke. I like the billet choke ***** from Killer Carbs (Dale Sanders) on ebay.
jackietan
04-25-2008 01:05 PM
