Hooray.. Dyno sheet
Old 04-27-2010 | 08:58 PM
kdubcr250's Avatar
kdubcr250
Originally Posted by BucksBike
Here is my Dyno chart from the 1,000 mile maintenance. Although the stage 1, Shortshots and SE pro tuner were done at delivery they waited until after the maintenace to do the dyno. I'd like to see a stock chart for comparison. It might be tough to read: Max HP = 75.62, max torque = 73.81
By the way where do you find instructions for imbeding an image in a post rathar than as an attached thumbnail?
LOL it the only why I know how do post a image. I just click the insert image icon a paste the link to the image on photobucket. I cant wait to see what kind of #s I get after I intall my heavy breather it just sitting on the shelf in the garage waiting for me to get to it.
Old 04-27-2010 | 09:10 PM
SHTFIT's Avatar
SHTFIT
Stage 1 A/C, PCIII and Drag Specialties Slipons at 1k miles
16VAFXDL's Avatar
16VAFXDL
Originally Posted by 09NightsterVB
Finally got it done. With the Heavy Breather and V&H Comp. 2-1 exhaust, there is a dip in the torque between 2500 and 3300 RPM. Not really able to "tune it out" but its not a bad set of numbers.
2009 Nightster 1200
Screamin Eagle Heavy Breather
Vance and Hines Competition Series 2-1
PCV
Nothing else.
Looks like your AFR is still pretty lean throughout the entire dyno run. If you get it a little richer, you might be able to pick up a little more power.
Old 04-27-2010 | 11:20 PM
brkbstrd's Avatar
brkbstrd
Here's mine when I just had SE1 intake, Cycle Shack slip ons, and a PCV with canned map. Probably better now, but I haven't dyno'd
Old 04-28-2010 | 06:58 AM
fox4's Avatar
fox4
+1 Fox4
2:2 pipes do tend to have a dip or two in their tq curve, BUT short 2:1 systems can have the same. Nice long pipes, and not too little resistance on the intake side seem to make curves much smoother. My 2-1 is actually shorter than the shortshots, but not by much. New pics to come.
We worked on it for bout 2 hours, and that dip aint goin anywhere. The V&H Comp 2-1's still have a pretty short baffle. Big torque difference over my sideshots. The pull is much stronger and consistent. I have also heard that running the stock cams/ springs over 6500 rpm is not the best thing. I told my tuner to keep it at 6400.
Anywho, next on the list is Thunderstorm heads, and cams (N3's maybe). Well see where that takes it.
I always say that if the good ole' butt dyno is happy then that is all that matters.
I have the sideshots and ever since I found the competition series pipe I have been contemplating swapping for it. Its just soo expensive. But I really think it is one of maybe two 2:1's that looks good on the sportster. Are you happy you made the switch as far as looks and performance go?
Old 04-28-2010 | 08:23 PM
SHTFIT's Avatar
SHTFIT
I think the PCV might be suspect for that torque dip. If you look at the print outs, the two with the PCV have similar dips. My PCIII doesn't have as severe a dip (I have 2:2's) nor do the others. Not sure how much of that can be felt by the seat of the pants, maybe not at all, but just a thought
Old 04-28-2010 | 11:00 PM
09NightsterVB's Avatar
09NightsterVB
I really do like the performance, and I really dont stay in my low end much, so I haven't really noticed the tq dip. Im gonna check with my other tuning friend and see if he's seen this before, and if he knows. The PCV is supposed to be more easily tunable than the 3.
Nighttrain88
Exhaust System Topics
06-04-2019 02:41 PM
RushKing14
09-18-2014 08:00 PM
Railridin
2014-2023 Touring Models
08-08-2014 06:57 AM
r0ck3r
05-08-2013 07:10 PM
Jeff's 1st Harley
09-17-2012 06:34 PM
Quick Reply: Hooray.. Dyno sheet
