stock exhaust
04-23-2010, 01:03 PM
stock exhaust
What is the inside of the stock exhaust supposed to look like?, Im trying to figure out if the guy hwo owned the bike before took the baffling out?
04-23-2010, 09:48 PM
black / grey
Wet black suggests rich mixture. Difficult to tell from the tail. Pull a spark plug if you are worried about the burn.
04-24-2010, 09:07 AM
When you look inside the exhaust hole, you should see a solid plate about 10 inches in. If the baffle was removed you will be able to see straight through.
04-25-2010, 01:00 AM
Speaking of exhaust....
With the new EFI engines, do you still need to manually reset or adjust anything when you go to a more open exhaust?
I know back in the carb days you'd have to rejet.......
Bakerbob
Stock Harley Take Offs
07-06-2015 09:59 PM
harleyrobert4
10-31-2014 06:58 AM
Rickr01
04-21-2011 10:22 AM
oldtimer61
08-10-2010 07:06 AM
wdatkinson
07-02-2008 11:37 AM
