No Front Brake!!
Old 04-14-2010, 03:24 PM
BurpleHugger's Avatar
BurpleHugger
BurpleHugger is offline
cHarley - thx fo rthe reply, the fact that color changes over time makes me feel a little better, or at least there is hope. I understand they can't be mixed but if it did have 3 or 4, it's too late I filled the MC last night when I tried to purge/bleed the line. If it is mixed, what's the cure?
Old 04-14-2010, 03:36 PM
Von_Zipper's Avatar
Von_Zipper
Von_Zipper is offline
You didn't read my post, did you?
Old 04-14-2010, 03:50 PM
BurpleHugger
Originally Posted by Von_Zipper
No need to drain master, once the air is out you can start pumping new DOT-5 thru until you are happy with the color coming out of bleeder. Alternative here is to disassemble calipers to make sure no old fluid is left in there, I'd probably go this route, this would be also a good opportunity to clean and grease pistons.
OK - figured out how to use the qoute button. Would this work even there we diffrent brake fluids mixed? What's the difficulty of disassembling the calipers?
Old 04-14-2010, 03:52 PM
cHarley's Avatar
cHarley
cHarley is offline
The "official" rule is that you have to rebuild the MC and wheel cylinder with all new parts and replace the brake lines.
People have been successful though with totally disassembling everything and throughly flushing everything out with a solvent, like brake cleaner, and letting it dry completely.
Old 04-14-2010, 05:51 PM
BurpleHugger
Alright, gonna go home in 15 minutes, pick up a bleeder, take the calipers off, clean 'em up good, grease the pistons, and bleed it. Appreciate all the input. I'll let you all know how it goes/went. if you don't hear from me tonight, that means I did somethign wrong, the brakes failed, and I died.
Old 04-14-2010, 10:19 PM
Tike71's Avatar
Tike71
Tike71 is offline
I'm gonna knock on wood for your behalf
Old 04-16-2010, 05:02 PM
BurpleHugger
soooooooo, went home, drained the remainder fo the fluid, disassembled the calipers, cleaned and greased the calipers, flushed out the MC and Brake line, filled with Dot5, bled it, and Whahlah!!! I got front brakes!! Thanks Ironrike71, VonZipper and cHarley. Blessing of the Bikes here I come!
Old 04-17-2010, 11:24 PM
michael95688's Avatar
michael95688
michael95688 is offline
I had to pump mine for an hour and 5 minutes... Now you need to start over. Bummer
fftoddster
04-15-2017 07:41 AM
crazymjb
EVO
05-01-2015 08:40 AM
Route66rider
09-26-2012 09:33 AM
mrgr8ness
03-14-2012 09:01 AM
BurpleHugger
04-14-2010 02:04 PM
Quick Reply: No Front Brake!!
