forwards back to mids on a nightster
my bike came with the forwards installed and personally being short i prefer the mids with highway pegs out front.
long story short i just bought a set of mids off the site here yesterday
and was wondering if i really need to pull the front pipe off to switch it
back to the mids? and if i do have to pull the front pipe will i need any
exhaust gaskets?
i have a roll away full of tools and i just want to be sure i have everything for the job before pulling it apart.
thanks in advance
exhaust gaskets?
thanks in advance
oh to answer your question,
yes you must pull the front pipe off. You will also need to pull the bracket that holds the pipes to the bike.
I know you need 1 size (8) allen wrench for the piece that is connected to the controls and the frame. all the other sizes im not really sure about i forget.
gl
gl
hey Doc,
if i decide to sell them i already have one person ahead of you
but as i told him i wont be sure until i can get the mids installed
(which wont be for quite a while) and then ride it for a couple of
weeks.
either way i will keep you in mind for them if i do decide to sell.
weeks.
You don't have to pull the pipe all the way off. All you have to do is unbolt the muffler from the cross-over/support bracket at the bottom and swing the pipe out of the way. No new gaskets would be needed for this. When I went from the mids to the fronts I did not take the pipe all the way off.
Good luck on your conversion - I think you'll like it.
And good plan on getting your tools together beforehand!
2007 Sportster XL 1200 Low
with the way i ride.
and thanks to fox4 for the tip i appreciate it.
