Wheels - Spin Balancing
Ok - dumb question - you don't need the spoke weights if you use dynabeads. Or at least their website says to remove the wheel weights.
Is there a trick to removing the weights mounted on the spokes? I apologize in advance for asking dumb questions, but I'm much more comfortable working on cars, not bikes.
The wheel should be balanced well enough by itself. It doesn't matter how heavy a rotating wheel is if it's balanced.
You're correct in theory, but not all wheels are created equal. This has been my observation over the years as an auto mech. The balancing process is for tire and rim together. So most of the time you really don't "know" where the imbalance is. It takes a sophisticated balancer to differentiate this info unless you try balancing the rim by itself first. (which usually won't happen)
Then I removed the weights and replaced with Dynabeads +1/2oz. With dynabeads it doesn't hurt if you add a little extra, they just move around as necessary and you have some extra to compensate if needed as the tire wears.
I'll never go back to conventional, ugly weights.
I've never seen a "sophisticated" balance machine in a motorcycle shop but I haven't been in every shop. I have personally balanced wheels for everything from a motorcycle to a semi-truck (before Equal came along). I've never needed a sophisticated balance machine to do it.
I will stand by my statement that it doesn't matter how heavy the wheel is if it's in balance (i.e. undamaged). No additional balancing material should be required because the wheel weighs a few pounds more than another provided there is no damage to the wheel itself.
We can't both be right, and my experience is different from yours. Car wheels are much wider than motorcycle wheels and can be off balance from side to side. This is just not noticeable with a motorcycle wheel which is less than half the width of a typical car wheel. Aside from damage to the wheel, it should be fairly well balanced by itself.
