Gear selection..?
Gear selection..?
Looking to see if anyone else has ran into this issue...I have a 2007 1200 low...@ 15000 miles on it. Had since new. Every now and then after riding a while when i stop it doesnt want to change gears...let out on the clutch a lil and i can shift... otherwise its just like its stuck between gears. Now it did this a for a short time last summer but it stopped...so didnt think much of it. But did it again about 2 weeks ago. Well I changed my clutch cable last week when installed a custom riser and now it seems to do this about every other time or so i stop. I Have adjusted the clutch inside as per the manuel and the cable to the lever @ 1/8th to 1/4 in play. Now it shifts fine and smooth... its just at a stop. And i did top off the fluid when i removed the cable... ith the bike upright... and the fluid it self seemed fine, as i changed it out at 10000. running pure senthetic. Any thoughts on what might be causeing this??? Thanks
Well i haven't heard that one before..lol but I know between my 04 and this 07 iv racked up about 35 thousand miles and never came across this issue till now. Still not sure why it would be happening randomly though....
Because the gear alignment when you come to a stop is random by nature. That's why you want to select your gear before you stop, while the gears are still turning.
And what about when im still moving and it doesnt select a gear?.. rolling to stop... up or down and its just not catching...feather the clutch lever a little then press down and it may or may not catch... ?? Is it still the same issue if the bike is rolling?
Ok well im just trying to cover all the bases.. yes it does it MOSTLY just at a stop.. but every now and again while at a slow roll... Just trying to get a variety of answers... Thanks
KPMC
04-19-2019 08:47 PM
1993mooglide
06-23-2009 11:11 PM
