Just changed to the Heavy Breather and had the carb adjusted and now the check engine comes on then goes out on a regular bassis ? Any ideas
I have been adjusting the Fuel /Air screw trying to see if this fixes the problem but it will run for a bit then the light comes on then 5 min later goes out ! Seems to run fine
Ok I looked it up on the internet and it's says backfire thru the carb so I guess I don't have it set right just yet and I believe I need to change the jet from 190 to 180 190 is what Harley had in it I think it's to big
PO562/PO563 Battery nut was lose FIXED
Part # ? 32889-04C
? 6100617
Looked up the part number and there is no such part ! Anyone ever get these codes ?
I can't figure out what your asking. It seems you found the DTC's and fixed the problem by tightening the battery connections.
Is the part number your looking for for the oil pressure switch? That switch is omitted from my 04 Parts manual, but it's a generic item and easy to find Click Here.
