Flashing turn signals- headlight not working
![Question](https://www.hdforums.com/forum/images/icons/icon5.gif)
Folks,
My buddy tore his Sportster apart this winter, and we were starting to put it back together and ran into a snag immediately.
We put the headlight back in, but it didnt work. I noticed when the key was turned the front LED turn signals flashed (I believe it was twice), so we installed the tail light LED's which also flashed with the front ones! The right back LED will not turn on has a running light, but works has a brake light and turn signal? The license plate LED is also not working.
This was the first thing we tried to put back on, and didnt get any further. The front and back end are off the bike along with the tank and seat, I dont see how this would effect the lights, I am assuming there is a bulb out or a short, but the flashing seemed like that should tell us something!
Any ideas? He told me the year of the bike, but I forgot, it is like a 1994 or 2004? Either way it is not EFI!
Thanks in advance!
Thanks in advance!
LED's are polarity sensitive. You have to have the the correct ground and positive wires correctly installed in order for them to work properly. 90% off all Harley's have the wires reversed because the regular light bulb will still work even with the wires switched. Check your wiring one more time.
Folks,
Thanks in advance!
Thanks in advance!
PM sent.
And Yes, load equalizers could be the problem with the signals, but not the headlight. Get it working first.
You can't tear down a bike and expect to put it back together again and have it work, if you don't have a Service Manual.
![Thumbs up](https://www.hdforums.com/forum/images/icons/icon14.gif)
I personally wouldn't tear my bike down because I am not so mechanically inclined, but I already bought the manual at the link you gave for my bike!
He told me he took the bulb to a 12 volt battery with nothing, so we are thinking the headlight is bad after being removed from the bike. Once he gets that going I will give him the bad news about the LED'S!
