2010 883 to 1200 conversion cost $2500???
#31
#32
XR1200 has the buell 1200 lightened flywheel, 2 into 1 ceramic pipes and .551 cams ontop of the weight reduction, suspension upgrades. the XR1200 will smoke any regular 1200 without even trying just like my 883 powered by a buell 1200 smoked regular 1200s all around, dude you REALLY REALLY have to go testdrive one of these XR1200s yourself or at least talk to a XR1200 owner these bikes are a quantum leap above and beyond regular 1200s
#33
#34
Will lower gearing effect top speed? Not necessarily slower, unless you can still hit the rev limiter in 5th gear with taller gearing. Indeed, sometimes lower gearing will allow for a higher top speed because the gearing makes up for wind resistance and allows the engine to rev higher in top gear. Horsepower of course making up a large part of this equation as well.
#37
Let me add up my cost for you my 2010 iron conversion
V-Twin 883 to 1200 conversion kit $450, Cometic gasket set $120, Ferrea valves $160, Energy One clutch diaphram spring $30, H-D SuperTuner $450, Valve job $80, Porting and polishing (my time and labor), Installation (my time and labor), Dyno tuning $450. THAT'S $1730.00
If you have an EFI motorcycle the only way to tune it is on the dyno and you have to purchase the VCI (H-D SuperTuner hardware). No if's and's or but's.
