Alarm issues
Old 03-31-2010 | 01:29 AM
Caruser4's Avatar
Caruser4
Default Alarm issues
So, I got the HD pager security system but the kit didn't come with the right instructions and I have no idea how to hook it up. Does anyone know or have a link to a write-up? I've tried searching but that didn't work either. If it helps, I only have the stock alarm system with no horns.
Old 03-31-2010 | 03:20 AM
50magnum's Avatar
50magnum
I would call the place or person you got it from and let them know of your situation, then get the right instructions. It seems to me to be a commo problem from what your post states, and by both the equipment and place of business. I don't have that item, but I would be on the phone asking about it from where you got it.
Old 03-31-2010 | 01:24 PM
yet_erp's Avatar
yet_erp
Default RE: Alarm Issues
I would look on HD's site. Find the part there and they usually have a
downloadable PDF with installation instructions.
Old 03-31-2010 | 02:13 PM
jerryw618's Avatar
jerryw618
well if we knew what model and year bike we might be able too help
Old 04-02-2010 | 12:59 AM
Caruser4's Avatar
Caruser4
I got it from a guy on here.
Sorry, how stupid of me. It's an '07 XL 883R.
Old 04-02-2010 | 03:19 AM
jerryw618's Avatar
jerryw618
ok 07 883 i have an 07 883 l , i just put an alarm in it, the alarm module goes under the battery , theres a hole under the battery it drops into ,the plug is in the wire harness that is in front of the battery , pull battery youll see the wire bundle towards front of battery compartment, the siren goes under the bike mounts between frame rails behind motor , connector for siren is also in the wire bundle by the battery
hope this helps . let me know if you need more help
Old 04-10-2010 | 02:44 AM
Caruser4's Avatar
Caruser4
I took out the battery and found something under the battery mount that looks like what you described. It said something about not touching, rotating, or moving it. I don't know if that's it but there are two connections under the seat frame that look like they'd connect to the harness that came with the pager system. Might that be it?
Old 04-10-2010 | 04:24 AM
jerryw618's Avatar
jerryw618
that is most likely it , the alarm module plugs in there goes down in the hole under the battery, attach the siren under the bike run wire up to connector by battery
Old 04-10-2010 | 04:57 AM
wtb3886's Avatar
wtb3886
Default Take a look at this page
http://www.harley-davidson.com/en_US...ts/-J02620.pdf
If this doesn't help post what security model you have
Old 04-13-2010 | 01:46 AM
Caruser4's Avatar
Caruser4
That's exactly what I needed! Thanks so much!
Quick Reply: Alarm issues
