Ironhead points
Ironhead points
I had the local shop put my cam gears and cover back on and now it runs like crap. I noticed that when I checked the points gap that when I had it at the top of the lobe (where you would gage it at) that all of a sudden the cam lobe moved and my points closed. I never remember being able to wiggle that cam lobe back and forth. Should it not be fixed, stable, not move? Can someone tell me something?
Yes, It should move. There is a weighted spring loaded breaker plate there to advance retard the timing. That is why you set the timing at a certain rpm. I sold my sportster along with the shop manual, but it is all in there. Just as a side note, my Sportster was an 84 which was electonic ign.. When the modual went bad I changed it over to points and condenser, along with the right coil for points ign. It worked great, and I could fix it.
